difference between 742 and 742b?
tom in nh
Hi all, some curiousity questions, What are the differences performance wise? Is it the same chassis? Interested in other useful info and tips too. Advance thanks for your help.
From what i can see, the 742B is the newer model, it also has a different engine to the 742.
You will find it will have the same chassis, same pump/motors. For the most part it will look exactly the same, the "B" is just a later model.. I believe the performance will be exactly the same.
I hope this is what you wanted to hear.
They are the same chassis and pump and motor like tazz said. One a 742b though they went to a two piece axle which makes changing wheel seals alot easier, like a hr instead of 24 hrs of labor too change a seal.
