2005 T-190. Code is for "door/transport lock-open/active". Was up working inside switch panel upper left hand side of cab that has A/C, wipers/fan/ cig lighter in it. Added another 12V power plug using keyed hot wire that was not being used for anything--it was in a White plastic "triple" plug that must be used for options I don't have. Now I get the code mentioned above. When I try to use machine, the wood "door" shows up on the screen and the the lift and tilt valve light flashes, and lift and tilt don't work. If I unplug the wire going to the door latch that has the safety switch on it, the code goes away and all functions work (but it would be possible to wreck the door as then I have no safety interlock). My machine has gold pkg, with foot pedals only. Did I fry something somewhere? There don't appear to be any fuses blown down under cover between your legs. Are there fuses somewhere else? What is usually the problem when code 78-84 shows up? Thanks in advance
