Count down timer on 865
robcurhuf
865 counts down like it should, skidsteer starts then while running count down starts again. You can use it with no problem. Just started last couple of weeks. I don't want to be hurting anything. We just serviced it, new filters and fluids can't see where that did anything.
i would check to see if its getting voltage at the glow plug when the second countdown begins. if it does you may burn out the glow plug prematurly.
Immediately after you start the engine does the instrument panel go throught the self test, that is, do all the lights come on in the instrument panel and do you need to refasten the seat belt before the pedals will work?
