Correction on the 763F bypass valve
Kitwoman53
The part I am talking about in the previous thread should be Lift Lock bypass valve. Need to know if there is a kit to fix a leak? Thanks
Do you mean the lift arm bypass valve that you manually pull out to lower the arms if you've lost power? If yes then unless the valve has been damaged it should be just replacing some o-rings. A Bobcat dealer can supply a kit to replace them.
