Cooling Fan
donner2dog
I just got a tree branch in the fan & broke 1 fin off, there is a vibration, is there a simple way to pull the fan off???? Donner2dog
Donner2dog: I cant help you with pulling the fan blade. If your fan is mounted on your water pump It could damage the pump bearing and seal to continue running it. Mike
I think your talking about the blower fan which blows air thru the radiator and the limb went thru the plastic louver , if so the only way to change it is to remove the blower box , which really isn't that hard a job , with no problems 3 hours should be more than enough time , 2 hours if you did it before , there is a thread on here that discribes the procedure , if you can't find it I'll explain it to you
