Cat 299D no auxiliary flow
rec177
Cat 299d3 someone ended up bending a lift cylinder and it was sending metal through the system and locking up the spools. Replaced everything and flushed the system. Everything works fine just not getting fluid to attachments now. No codes, rocker switch is working, took off and tested the solenoids on auxiliary block they are working, getting the image on screen that it's supposed to be sending fluid but it's not trying to send anything. Triple checked everything that was worked on and it all seems good. I'm at a loss.
