CAT 242D
John-JET
My CAT 242D stopped working while in use. Tried to start and seems like it wants too but just wont turn over?
Do you mean it turns over but will not catch?
If the engine is turning over but won't start it is most likely a fuel problem. Could be a clogged filter, a bad fuel pump, air in the line, a broken off intake line in the tank, a cracked intake line, a bad fuel shutoff, water in the fuel, etc.
First thing I would do is check the fuel filter. See if there is air in it first. This would indicate the intake line is open somewhere. If there is no air in the filter then drain it into a clear jar and let it settle to see if there is water in it.
Thanks brdgbldr!
Yes it is turning like it wants to start but will not catch. We had it running and it shut off and then would not start.
I will check the fuel filter like you suggested hopefully tomorrow and will let you know how it goes.
Thanks again!!
