Case tr310
Brian65610
I have a 2015 case tr 310 skid steer. I had to replace the battery and afterwards it would not crank. I found a problem with the battery disconnect switch so I bypassed it and now it will start and run. Unfortunately now I cannot get the hydraulics to engage. Here’s the codes I have found: 1905,5511, and 4741. This machine has been out of service for over a year so any help is appreciated. Thank you.
Well here’s an update if anyone is even reading this. Turned out the battery shut off switch was bad. Wired around this and now it will start and run
Thanks, Brian. I've got a neighbor who has a T340 and his has been down for almost a year now. He paid a Case dealer mechanic thousands of dollars to come out and fix it, but the guy couldn't find the problem. He told Jeff he needed to buy a complete wiring harness and install it. Besides buying it (used), he paid Case something like 8 grand for their service call, which was a couple of days, and now he says they're telling him a new harness will be 6 or 7 thousand for the part alone, not including installing it. I feel really bad for the guy. I told him when we met 5 years ago when we both bought our acreage next to each other that I rent any heavy equipment I need because I work them hard and I'd rather let somebody else do the maintenance. I'm always busting a hose or fitting, and although use skidsteers and mini excavators pretty often on our 43 acres, I don't want to have to deal with the expensive repairs and maintenance. I rent from a local tool rental place and the 10% for "insurance" is worth every penny.
