case sv280
golfmechanic
after sitting for a few days wont start without a jump battery holds at 12.2 passed the load test had the wiring harness replaced 2 years ago for the same issue and now its back tested all relays diodes and switches cleaned all cables and terminals im at a loss for where to go from here
See if the starter will turn over by connecting a wire between the power cable an the start wire on the starter solenoid. These are the same points you would hook up a remote starter to, which you can also do.
If it turns over the battery and starter are good and your problem is somewhere else. If it doesn't, your starter solenoid could be bad.
I've had bad ignition switches, or connections, give me similar problems. So that's another area to check.
