[email protected]
- Joined
- Jan 27, 2024
- Messages
- 156
This Skid steer always worked well but just recently the right drive stopped trying to turn. Looking for ideas on a simple fix or check this and that. Chain drive.
Thanks for that. Is yours a Case? I was hoping for other than what I think maybe the situation as you mentioned. Like a streched cable to the control at the valve bank. Did you have it fixed? This small case 1818 is hard to get into much less fix it. This one I have is a 1987vintage and had 300 hours on it back when I got it. The simple fact of the matter is it's kind of useless as it sits now but I can move it. I may just call the people that had it to fix her up. Time for me is the beast. No Hydrameter and all that would help but do not have that any longer.Mine stopped on left drive(sitting in cab left side) found it to be drive pump can't really find right pump for it doesn't look fun to change
Yes it is a case 1818 gas Onan 2 cylinder believe a 94 ,vin jaf0073470 right works bucket everything else works but left hydraulic pump behind the set makes a lot of vibration with a noise like something has failed inside,haven't had time to take apart but I'm thinking of just getting it fixed somewhere as I have alot of other things to doThanks for that. Is yours a Case? I was hoping for other than what I think maybe the situation as you mentioned. Like a streched cable to the control at the valve bank. Did you have it fixed? This small case 1818 is hard to get into much less fix it. This one I have is a 1987vintage and had 300 hours on it back when I got it. The simple fact of the matter is it's kind of useless as it sits now but I can move it. I may just call the people that had it to fix her up. Time for me is the beast. No Hydrameter and all that would help but do not have that any longer.
Hi it's been a while and I wonder if you ever found the issue with yours and how it was fixed. Costs? ThanksYes it is a case 1818 gas Onan 2 cylinder believe a 94 ,vin jaf0073470 right works bucket everything else works but left hydraulic pump behind the set makes a lot of vibration with a noise like something has failed inside,haven't had time to take apart but I'm thinking of just getting it fixed somewhere as I have alot of other things to do
Not yet just don't use it all the time and it is way to cold to play with it. Temps under 20 degrees doesn't help motivate me. WI. weather.Did either of you solve your issue? This sounds like an issue with the brake pin stuck, given the "dead heading" sound.
I have 18F now but not much better.I have the same problem with a 1816c, what is the brake pin you refer to.
It sounds like the drive pump is cavitating, lots of noise in the back, even when no drive engaged and belt burns off when engaged.
Took the drive pump apart, it is in good shape, now going to cross the lines from opposite side and see if I still have the same problem in reverse to check the driven pump. Have to move the machine inside as it is now -10 C so may be awhile.
I can get you some pictures later tonight or tomorrow. This sounds like a different problem and I think the 1816 has a different brake mechanism than the 1818's.I have the same problem with a 1816c, what is the brake pin you refer to.
Which one is the drive pump? Or Pumps. See mine is up North sitting and I am South of it 200 miles so I don't get to that job as often as I want to. I also have the parts manual and things there so I cannot look. To cold now to play with it.Mine stopped on left drive(sitting in cab left side) found it to be drive pump can't really find right pump for it doesn't look fun to change
Any Updates on your Pump change Mr. brufarris ? Or any pictures of the pump you are changing or hope to change? Thanks again.Thanks for that. Is yours a Case? I was hoping for other than what I think maybe the situation as you mentioned. Like a streched cable to the control at the valve bank. Did you have it fixed? This small case 1818 is hard to get into much less fix it. This one I have is a 1987vintage and had 300 hours on it back when I got it. The simple fact of the matter is it's kind of useless as it sits now but I can move it. I may just call the people that had it to fix her up. Time for me is the beast. No Hydrameter and all that would help but do not have that any longer.
