one thing i was trying to get the headlights to come on, i think its the two buttons on the right console below the park brake button. when i push them the lights dont come on but the button lights up. when i have time i will check for power at the lights, wheare is the fuse panel located? thanks johnWhich buttons are you referring to. There are different joysticks per the options on the machine. Left hand trigger switch is for two speed. Right hand trigger switch is for ride control. Left hand thumb switches are for single and dual flow hydraulic, and turn signal. Right hand thumb control operate auxiliary electrical control, and horn.
The fuses and relays are located on the left side of the operator under the cover between the seat and the side of the ROPS. use the thumbscrew to access the fuses and relay. The fuse location decal is located on the bottom of the cover.one thing i was trying to get the headlights to come on, i think its the two buttons on the right console below the park brake button. when i push them the lights dont come on but the button lights up. when i have time i will check for power at the lights, wheare is the fuse panel located? thanks john
We are starting to get this new machine figured out, one thing i need help with is how to make the loader float we are going to be plowing snow with a angle plow. the controls are the old style (not pilot control) thanksThe fuses and relays are located on the left side of the operator under the cover between the seat and the side of the ROPS. use the thumbscrew to access the fuses and relay. The fuse location decal is located on the bottom of the cover.
According to the owners manual, When you put the left side loader control lever in the maximum inside position, the loader lift arms are in float detent. Hope this helps, and Merry Christmas.We are starting to get this new machine figured out, one thing i need help with is how to make the loader float we are going to be plowing snow with a angle plow. the controls are the old style (not pilot control) thanks
Hi Mate, did you end up getting a manual? I am looking for a workshop manual for a sr130 skid steer CheersDoes anyone have a Case 430 series 3 skid loader operations manual they could send me. Our manual got ruined in the weather. my email is [email protected]
