Case 430 coolant
Fatman1624
What type of coolant should go into a 430. Currently there is not much left in it and is snot colored/viscosity. Should I be worried about that?
I would say yes ,as I do not know when was the last time you checked the coolant,but it had to go somewhere . and if it is discolored I would guess it is mixing with the engine oil, figure it out first ,do not just refill the coolant.
as far as a type( peak final charge) is good stuff for diesels and industrial gas engines.
Case used normal ethylene glycol, yellow hd diesel antifreeze.
Diagnose the problem.
Depending on the circumstances, flush/change coolant system, check oil, pressure test coolant system.
May be a big problem internally or a simple severe lack of maintenance.
