Jul 11, 2010 #2 W wesg1234 New member Joined Jul 11, 2010 Messages 2 one side of the motors isnt pulling, is there a linkage that can be adjusted or how would i go about checking the drive motors
Jul 11, 2010 #3 T Tazza Moderator Staff member Joined Dec 7, 2004 Messages 16,840 You should be able to swap them from side to side to see if the problem moves. Check the linkages under the cab to make sure they aren't lose.
Jul 11, 2010 #4 OP OP W wesg1234 New member Joined Jul 11, 2010 Messages 2 Tazza said: You should be able to swap them from side to side to see if the problem moves. Check the linkages under the cab to make sure they aren't lose. Click to expand... awesome thank you
