broken bolt removal is an art. if you driil all the way thru so much the better, do not break off an easy out you will not drill these out ,tricks ? smack once with hammer. heat to break loctite loose but do not temper steel or you wont be able to drill 180f loosens loctite red or blue not sure about green? worst case i got adude with the coolest macine ever it send a micro air arc to burn out without ever touching a thread,use him all time. and reasonable.loctite has a product out called freeze and release part#996456 there are many methods,many theroys my best luck comes fom drill thru heat and smack.and use an easy out, would like to hear from old m on this one.or anybody else for that matter , these are lessons learned the hard way.any majic tricks old dogs can learn .and by the way pb blaster is the greastes stuff ever invented.
