Brass Filters
Stephend
I have 753 and just recently pulled these 2 brass filters; one that comes from the hyd. Oil tank and the other from a line that appears to come off the hyd. Pump and goes somewhere to front. I just cleaned them with diesel and blew them out with air at about 90 psi. The one from the oil tank was a bright color but the one from the line was darker in color does that mean anything? How do you know when to replace them or do you ever need to be replaced? The unit has about 1500 hours and is a 1999 model.
Administrator
Admin
I don't think colour means anything.
I see no reason why cleaning with diesel and air won't work. I have done it a few times my self.
S
Stephend
Thank you. I have not own a Bobcat for long time and need all the help I can get.
Fishfiles
A important part of the bronze colored case drain filter is being sure you put the spring and direction of the filter back together the same way it comes apart or it won't filter
