Gearbox, thanks for the advice. I'm very familiar with the clutch shaft now so getting to them isn't a big deal. I appreciate the advice about the holes though.
Where my leak was, I noticed that the lock washer was there but there wasn't a lead washer to be found. Rather than order one, I melted down some lead, poured it in a piece of 2" pipe. Was it cooled, I chucked it up in the lathe, put a 7/8" hole in it and then faced it till it was the right thickness. Worked pretty well…that and the black RTV I put on it.
On a different but not unfamiliar note, my right rear axle seals are leaking now. Looking at it, it has the same brass sleeve on it that was on the left rear when I replaced it. I already have some seals and am think I'll just make my own sleeve this time rather than ordering one. The PO said that he had those axles done 2 years ago. Whoever did the work didn't do great with the seals, but if the bearings were replaced 2 years ago, I don't know that I was to spend the money to replace them.
I also spent some time cleaning my drive belt. I have a new one on order but with a little cleaning it is performing better. Not 100% or even 75% but it's more than it was.
One minor thing is that my alternator light isn't going off. I don't think it's charging either. It's a 10SI 3 wire. I tested it with the motor running and was only getting 12.3 volts so a bit less than the 12.5 with it not running. The alt light is hooked up correctly. I unplugged it from the alternator and the light does not come on. Not sure how to troubleshoot this thing yet.
