Bobcat t770 engine removal without pump?
robdean
Removing the engine from the bobcat t770 doosan engine. I have the disasimbly instructions. As i work through them i am not seeing anything about taking the belt off the fly wheel to seperate the motor from the pump. Am i missing it or do i have to pull the entire motor and pump out at once? I was hoping to just pull the motor. As i am getting through the directions its having me take off hydraulic hoses from the pump. Do i need to remove them both or am i missing something?
I’m not sure about the t770 but on my A300 the manual actually has a diagram for building a brace / framework to remove the engine and pump together.
Ya the manual for mine does not show if its just the engine or both but it never seperates them so its going to be both. I was hoping someone with knowledge could tell me if its possible to just do the engine.
So it was both and i am sure you could try to take just the engine out but the bell housing would need to be removed to do it and the bell housing in this engine also holds oil. This would be very hard to put it back in without a gasket or leak issue at the angles you are going to work in. So i took it all out.
