Bobcat T300 needs travel adjustment
7254greg
I have an 2005 Bobcat T300 with standard bobcat hand and foot controls. I have noticed that my right control lever moves approx 2" forward more than the left which causes the machine to turn to the right very bad. My left lever wont move near as far and tracks very slow. In reverse , it is equal and functions perfect. Does anyone know how to adjust this ? Also, if you have an illustration, that would be very helpful !! Thanks
Lift the cab and check your linkages all the way to the pump for wear. They should eb nice and tight.
There should be two bolts per lever that you can loosen and adjust the location of the steering levers. This will allow you to move it so it does not bottom out on the part that the levers.
