Buckett Control peddels Locked no code no power to lock solonoids, all four lights are on It was working fine when it was parked the day befour? Everthing works but the foot controls buckett will not rase or tilt. any help would be appr.thanks Jim.
Thanks for the good answers You guy,s are the best!!! I think I can Fix it now.But its good to know I can get more help from good people lik you thank verry much Jim. Atl Ga.All 4 orange lights on the bics instrument panel light? The ones that come on when you push the green button. This is just a problem with the main hyd valve. After you seat bar and the press to operate button are activated it sends 12v + to a coil on the main hyd valve that unlocks the lift and tilt functions. Your parking brake comes off and you can drive around still? If you look on the valve that you foot pedal linkage is hooked to, there should be 3 coils. (electric operated valves) 2 of them operate you front hyd outputs (these 2 wil be on the 3rd hyd valve spool, 1 and 2 spools are hooked to your foot pedals) and the third coil will be kinda off by itself on the valve without a twin. It will unlock the loader lift and tilt if you put 12 v to it. This will get you moving temporarily, but you are going to need the help of a tech with the diagnotics computer to solve it. Unless you can find a broken wire or a bad /loose ground. Regards Ken
Could be the doors wiring harness if it’s not connected. Check that out.Buckett Control peddels Locked no code no power to lock solonoids, all four lights are on It was working fine when it was parked the day befour? Everthing works but the foot controls buckett will not rase or tilt. any help would be appr.thanks Jim.
