bobcat s250
gofur
got error code of 32-04 which means that acs not communicating with controller.......anybody help with this ....suggestions
Easiest and cheapest first step would be to unplug every connector you can find and look for corrosion, give a spray of contact cleaner and refit. Also check any ground wires for bad connections at the chassis, intermittent grounds are common issues.
