I own a 2005 Bobcat S185 with under 1,000 hours. When the machine is idling and at lower RPM settings the hydraulic pressure light comes on and code 05-14 displays. An audible alarm will come on and the machine will shut off automatically. It then takes a long time to start if I let this happen. If I throttle it up before it shuts down the light will go off after about 5-10 seconds and the code will go away. It seems to operate just fine. No loss of power and the hydraulics are quick and responsive. I replaced the pressure sensor under the hydraulic filter and checked the drive belt. Also, it is full of fluid with no leaks. Any ideas?
