Bobcat S185 owner. Need help with code 76-73
markmor8
I've seen others with the problem but never see the solution. I've already replaced the left hand panel. Cannot find wire #9200? Any help would be appreciated.
Thanks
Finally found it. It's a purple wire under the cab. It has good continuity to the LH and RH panels from the connection under the cab. It goes to the controller next. I will check the connection their in the morning.
Continuity was good all the way to the controller. Sending the controller,LH panel and key switch panel in to be tested by ISOSCELL.
