ags_virginia
- Joined
- Jun 25, 2022
- Messages
- 4
Hi, I recently purchased a Bobcat 853 (SN# 510126350) equipped with the Apitech front auxiliary control valve, but discovered that the valve only operates in one direction. Front auxiliary electronics are working fine, and both solenoids receive 12V power when function is triggered by the switches. I also ruled out the solenoid malfunction by swapping the solenoids. There is no audible change in engine / load when malfunction is observed, and so it seems the problem is with the valve body itself.
The service manual is silent with respect to "rebuilding" the Apitech valve, which is now obsolete. The parts diagram shows the solenoids (#27) and pilot orifice (#26) as separate parts, and also states that the replacement solenoids have an an orifice build-in and the separate orifice (#26) needs to be removed when replacing the solenoids. In my assembly, the orifice is built into the solenoid (tiny ruby orifice), so I imagine it was replaced at some point. I tried to see if maybe there was an old separate orifice left in the assembly which could be plugged, but nothing fell out of the solenoid port, and I could not pull anything out with a seal pick.
I am speculating that the following root causes could exist:
- Pilot port delivering hydraulic fluid to the spool is obstructed
- Spool rod is obstructed / has high resistance in one direction
- Tear down existing valve, and attempt repair by cleaning / blowing all the passages with compressed air, and and replacing whatever seals I can still source from Bobcat, McMaster, etc.
- Contact Parker (who purchased Apitech) and see if they have some alternative valves in the same form factor
- Replace with a different directional valve (i.e. Eaton) that matches or exceeds specifications of the original Apitech
