Well since I started this thread I felt that an update is needed at this point. Thanks for everyone's input and is all valuable. As far as the preheat question, yes my 843 has glow plugs and found out that the previoius owner had replaced the ignition switch. The one he installed was just a generic switch with only off, run, & start position. I went to my dealer and bought the proper switch and now have my preheat position. In the process of changing the switch, I've run into a number of wiring issues and thanks to the manuals I am able to get them straightened out. One of them has to do with the quick disconnects in the cab to the left of the seat. The ones you need to disconnect when you raise the cab up. One of the connectors has been smashed (distroyed) and the wires are just hanging. Previous owner sure didn't take care much. Anyway, does anyone know if the connectors can be obtained without buying the entire wiring harness? I don't want to just hook them up without a means to quickly disconnect them. Parts manual states that they are part of the wiring harness and not listed seperately. Anyone have any good ideas as to a work around? As far as the ether.... I agree it isn't good but as Tazza & Stuz say sometimes you just have no choice. When I did use it I would only put a small amount into the little rubber spout at the bottom of the air cleaner. I am hoping that now that I have my preheat back it will not be needed. I want to get the wiring issues all back to normal first and I will then report back on that. No doubt, ether has no lubrication but going through the air cleaner this way does not stop the deisel fuel that the injector pump is supplying to the injectors.
