Bobcat 763g runs 30 sec than shuts off
Jeeper78
Bobcat 763g starts fine but only runs for 30 seconds or more than shuts off. And a red hazard symbol lights up with a exclamation symbol What could this be. And how do you check the codes on these machines. Thanks in advance!
Hold the "Light Button" switch down for a few seconds and it should display the code.
What did you do to fix it?
Checking for codes is a good start.
The shut down after 30 seconds is it trying to save its self from damage.
I think the major things it looks for is low engine oil pressure and low or no charge pressure. If these are detected, it shuts down in 30 seconds to try and prevent permenant damage.
I checked the codes 13-06. Fuel shut off. I just swapped a carrier reefer engine in my machine wondering if the fuel shut off is different?
Were they both the same looking ones that mounted to the outside of the engine? The other style was for the DI engine had a shut off solenoid that has no external moving parts.
It never hurts to swap the solenoids if it was the external one and looked the same, just to be sure.
there was an add on timer module added to these unitis. the purpose was to prevent low hr solenoid failure, easily discernable visualliy by xtra mod bolted on by right hand lower door hinge
I know the f series had the external timer. I thought the g series was controlled by the controller
