Bobcat 763 heater
shadesofidaho
My supply comes from the water pump by-pass and does not have enough pressure to circulate properly.Is there any other place on the 2203 you can get water pressure?The core is clear the control valve is ok as is the thermostat. Thanks Joe
I believe they place a restriction somewhere so the motor has a harder time pumping the coolant back to the lower engine block from the thermostat housing, thus forcing the coolant through the heater core
