bobcat 753g switch panel wiring
I,m trying to refurb a 1999 bobcat 753 the wiring at the switchgear has been tampered with and I cant find any diagrams with the correct colours that I have in front of me
Are you talking the switch panel where you start the machine or the control levers?
yes on the panel on the left hand side there is a ignition switch, a light switch a diagnostic socket and another switch also in the back of that panel there is a 4 way wire connector that I don't know what its for ? anyone have any ideas
Sadly i don't have a 753g i can take a picture of the wiring on... The wiring shouldn't be too complicated though.
There should be power from the battery, non switched, look for a wire with +12v on it, there will be glow switched power, orange with a black stripe? black or white from memory. There should be one for start too. The problem is, i can't tell you what pins these wires go to on the switch....
Not sure what the 4 position switch is, as the G series panels have push buttons, not switches from the factory.
hi I have found out that one set of wires are for the lights I just need to work out what the other 4 wired socket is the wiring colours are blue , green with red , 2 x black on one connector, and an orange wire with white and black wire on same connector . I,m looking for new block connectors if anyone knows where to purchase
Black will be ground, Orange is power, i don't remember what one is switched, but it is either orange/white or orange/black.
The connector with black and orange wires, sounds like that could be a short right there.
The plug looks like it’s factory fitted with the orange and white with black I will get a test meter onto it
