Hey my name is Chris I just got this Bobcat when going forward the right side will stall for a second then it will go or if when it stalls if you reverse it then go forward it helps some. Reverse on the right side work fine and the forward and reverse on the left side work fine as well. The linkage appears to be right. Just searching on the web I read it may be a problem with the replenishing valve . What do you all think ? My shop manual has almost no info on this valve . Can you tell me wear it is located at and can it be cleaned or will it need to be replaced . When the machine gets warm is when it starts this . When it is working it is srong it will spin the tires under a load. Any help would be greatly appreciated . I believe it is a 97 model. Thank you, Chris
