Bobcat 751 fuel consumption
dae06
I recently bought a 751 Bobcat with the fuel gauge not working. Anyone have any rough estimates how many gallons per hour this thing will use. I will be doing pretty much straight dirt work with it. I definitely don't want to run her out of fuel. Thanks
Sadly i don't know the figures, it will also depend on how hard you are running it, be it load and the speed at which you are running it. Figures i have seen on the net show 1.3-1.4 gallons/hour BUT that was also under no load, so not real world figures.
Have you looked into what's wrong with the gauge? It could be the sender or the gauge it's self. If you take the panel off and short the S connector to ground, the gauge should read full. If it doesn't move, there is a good chance the gauge is bad.
The sender is the last resort, it's not in a great location to remove.
