Bobcat 743 V2203 install broke rear crankshaft bolts
I like map gas yellow tank better than propane but it does not have to be to hot for big bolts with blue locktight just a bit harder than lock washers but will help
Everything came apart easily. I cleaned up the threads and used blue Loctite again and torqued. New rear main seal and crank sleeve. No leaks from the engine and all seems well. Next will be a few hydraulic leaks I have found. Thanks to all for your help!
Good to hear
