wranglers53
- Joined
- Dec 11, 2015
- Messages
- 1
I have a leaking seal on the viscous pump rear on shaft the motor turns for the hydrostatic pump / transmission. I had the motor pulled and I'm trying to remove the splined gear off the shaft to get to the seal fi does anyone have any advice on what puller in can use to remove gear off the shaft. I've tried every type of puller and none seem to pull the gear off the shaft. It has moved a little bit but won't seem to come off .
