Backhoe Model differences
Greatdaen
The bobcat website currently lists one of their backhoe models as the 8811. There is a unit for sale listed as an 811. Does anyone know what the differences are? Will an 811 fit on a 763 skidsteer? What modifications are required? Thanks, -dch
I'm farely certain the 800 series hoes are too heavy for your 763. They are usually paired with a 709, or a 909 is the older one that uses the 2 trailer balls to steady the upper part of the machine. A hoe for a 763 should have about a 9' max dig depth (which the 709 or 909 does) incase you are looking at brands besides bobcat. I'm not sure what the difference is between the 811 and 8811. Ken
G
Greatdaen
Ken, Thanks so much for the information and suggestions. New to bobcats and bought mine to help build my house. Would like to add a hoe, but - as you can tell - know little about the attachments. Thanks again.
Tigerotor77W
The 8811 replaces the 811. The 811 served as Bobcat's largest backhoe offering; when the S250 and S300 came out, the 8811 took over that position. I'm not sure what the primary differences are, but as Ken mentioned, the 811/8811 will probably be too heavy for your machine. (Note -- they should fit the Bobtach, but your digging performance will suffer.)
Eric
Everything Tigerotor77w mentioned is correct. The only difference between the 811 and the 8811 that I know of is the backhoe frame where it attaches to the bobcat. The old 811 has mounting hooks just outside the lift arms. Well with the new K Series loaders, the lift arms are beefed up and much wider than the older skidsteers. This makes it impossible to mount an 811 on a K Series. The new 8811 now has to mount inside between the lift arms. You can actually turn a 811 into a 8811 by swapping out the mane frame of the hoe. Everthing else is the same. If you wanted to change a 811 to a 8811 is change the main frame.
musclesbenz
Here is the backhoe/skidsteer model overlap.
