Hi all - I'm new here and have a question about a hydraulic interface between my JD 250 and a Boss V plow designed for a truck. I'm hoping to adapt a Boss V plow to my skid steer so that it works the same as on a truck - form a scoop, angle both directions, or a V. I also have some concerns about floating the blade when attached to the skid arms. I've read here about using a flow restrictor so the cylinders don't work too fast with the skids presssure, and I'll be doing that. Otherwise it should be pretty straighforward, but diverting the hydraulic flow between the cylinders is beyond me. Anyone here know what kind of valve I need to do this? Any other comments or suggestions about this type of arrangement are also appreciated. If you could reference a specific item(s) in a catalog that would help a lot. Thanks in advance for your help.
