A/C Question
wkola
Hi All
I have a 2001 773 anniversary edition 56 hp. When i bought it the guy Had not used the a/c or heater in it for 10 or 15 yrs because the fan motor was bad. So replaced it and the cleaned the evap. and heater coils and changed the filters out and in there was still freon pressure on the line. so it blew warm and i drained it and pulled a vacuum on it for a hour and refilled it back and now i notice the best i can get is 52 degrees blowing out the vent by the seat and its 80 on the temp outside and humid.
The repair guide has the pressure in it and the low and hi side are in spec. at 2000 rpm Is this the normal that this will do or am i missing something .
Thanks for any help
Pat
52f is pretty cold, i wouldn't argue with vent temperatures
You don't want vent temperatures too cold, or else you turn the evaporator into an ice block and that won't move a lot of air
