Jessafarms
- Joined
- May 3, 2019
- Messages
- 1
I have an 843 high flow with cracked hyd pump. These triple gear pumps are not available from bobcat or anywhere else. Double gear pump is also not available but dealer did find one nos after long search. I am told this conversion is possible as long as high flow circuit is deadened. I have installed new pump and have hooked high flow lines together one time and also capped the lines at the pump and both times it has ruptured hydraulic filter and is making bucket roll down. Dealer says lines should be capped. There is also a after market parts rebuilder/ dealer online that says this can be done but when you call them for a kit and instructions they can’t find them. Any ideas? Thanks
