i have the arms but quik-tach is gone to boston. i have hyd.cylinders,fuel tank,perkins parts, kiki? injector pump.cab with dash. i have the tilt piston but ring at top is broke off will need new one welded on. e-mail if interested i'm in western mass.im looking for bobtach plate/ arms so i can replace the older case style adaptor in my 1835C. im also located in mass
do you have the hydraulic tank thanksi have the arms but quik-tach is gone to boston. i have hyd.cylinders,fuel tank,perkins parts, kiki? injector pump.cab with dash. i have the tilt piston but ring at top is broke off will need new one welded on. e-mail if interested i'm in western mass.
i have the fuel tank [forgot if it is a split purpose] if it is seperate i do not have it .still have the cab,arms,hyd. cylinders, perkins parts , fuel and oil fiter assemblies , starter c-ya stevedo you have the hydraulic tank thanks
Detroitpowerim looking for bobtach plate/ arms so i can replace the older case style adaptor in my 1835C. im also located in mass
