Heetseeker
- Joined
- Dec 6, 2015
- Messages
- 12
I've searched these forums and ran a couple tests, but here's the issue: Click, no start. New battery, cables, charged and new alternator, all tested out good. With a meter, the wire coming from the key switch (white) goes from 0-2.4volts when I turn the key to start. No power, to only 2.4 volts going to the starter solenoid. Jumped from the + on the battery to the S post and the starter turned and engine ran. Key off, tried to start, Click. Not getting enough volts through the relay behind the coolant tank? Bad relay? Any advice would be great. Thanks!
