The fitting is a push/snap together fitting , I forget the name of it , I think it's Push-Lock , there is a internal ring , o ring and a back up ring which goes inside the female side and when pushed in it snaps together very easy , you can buy a kit with the 3 parts in it for like $10 to repair a leak at the fitting , it is very hard to get it out with out the tool , but possible , the tool resembles a widened out tuning fork , I don't like this fitting , machines that use a hammer have a tendency to pop off the hose at the filter head where the fitting is also used , I think this mostly happens on machines that have a low nitrogen charge and have a wicked back pressure on the system , you know when the hoses to the hammer violently shake around , the T 140 is notorious for popping off , It's been out for a while now and the fitting is available from a AreoQuip/Eaton dealer so hoses can be had after the dealer , I have had to change a few oil coolers because the inside the welded female on the cooler gets worn out and the hose won't stay on , I have a few times had the radiator shop weld a JIC fitting to the cooler and replaced the hose with the old school JIC type , I have also wrapped tie wire around the fitting to the hose to keep it together , Bobcat gets $43 dollars for each one of the tools , it could be easily copied with a plasma cutter or touch , the tool will bend pretty easy so care needs to be used and not brute force ----------------- Tazza , could you give a brief description of how to post pics again
