My 763 stopped moving because the hydraulic reservoir emptied into the chain case via a failed main seal on the drive motor. I installed a washer and seal kit on the hydraulic control unit (all 2 thousand pieces) and then replaced both main drive motor seals. After a few minutes of operation, the hydraulic reservoir was empty again, and one of the drive motor seals was blown out. Next, I replaced the main relief valve, and a port relief valve in hopes that would fix what I perceive to be an excess amount of pressure on the drive motor seal. Still no luck, the seal blew out again. Any suggestions?
