753F Spool seal replacement question
Phild58
I might have posted this in the wrong section, trying again here. Hello members, and thank you for the add. I have a question about the seal replacement on the spool valves for a 753F model. I have managed to disconnect the pedal linkage at the front of the valve block (PITA job because the clevis pin was in backwards and I couldn't remove it without splitting the clevis) and have removed the cover at the rear. All good, except when I try to pull the spool out it feels like it hits a hard stop. It seems free around the rubber boot at the front so I expected it to just pull the shaft out of the boot and I could take it out from the rear. Am i missing something? Thanks in advance, Phil
