Just bought a 2000ish 753g with 3000 hrs. and it has a shutdown problem. This is a keyless machine and when I hit the green start button, it starts right up for a second or two, then beeps once, gauges/bics goes blank and engine dies. The fuel shutoff closes at that exact moment too. I can manually hold the fuel shutoff open and keep it running but bics is off with everything locked and I can't even move the machine. It appears that the previous owner replaced the fuel shutoff solenoid and the oil pressure sensor. I have checked the fuses and relays and they appear to be fine. I have a 763 of similar vintage and can swap parts for testing purposes Thanks in advance
