75 M500
Robyn2778
I have a 66 M500 that won't start. I was running it and blew a hydraulic hose on bucket. Replaced line and check fluid level. Went to start it but nothing. Lights turn on and plenty of gas but won't start. I know the bucket is not completely level and not sure if that's the issues. Any ideas would be appreciated
I assume that you still have the 24 hp kohler opposed twin, check for spark, check plugs, points maybe replace condenser ,look at plug wires ,and you should run solid wire plug wires on these engines, no resistor wire and use non-resistor plugs if you can.
