sblanchard
- Joined
- May 20, 2010
- Messages
- 4
I have a 743 skid steer that I bought used that has a strange (non standard) configuration off the water pump. There is a Y that has as short hose to the Thermostat and a longer hose that goes to what I think is what should be the coolant drain plug on the side of the block below the injectors on the left side (as looking at the engine from the back). I have purchased the correct hose (short L hose) to connect the issue, but didn't know if anyone knew why someone would have changed the plumbing to be this way. Do you think it was to provide better circulation? Also, what is the flow direction in the cooling system? Thanks. Scott
