742B CARB FIX
tlaskey
OK, This is the first time posting but have read I have had carb issues on my 742B with the Mitsubishi 4G32 forever....
Rebuilt it over and over, gets better and worse. Finally had it!
Bought a carb for a Mitsubishi lancer, Installed with some modifications and
IT RUNS BETTER THAN IT EVER HAS! Right now I still have the secondaries plugged and running off only the single barrel like the original carb.
The last picture kinda shows wher I removed the linkage for the cars cable and added the lever for the original bobcat linkage. all worked great.
Carb MD-081100, MD-006219 for a Lancer AND before you say that doesn't have a fuel shut off solenoid......I added a fuel tank transfer solenoid
set up to flow fuel when the key is on......done.
When warm the machine starts with the throttle at idle with NO CHOKE and just purrs. I've been fighting this forever.
I made a half inch aluminum spacer and used the plastic spacer from the original carb to get hight to keep linkage from interfering with manifold. Made longer control rod from governor, and will open up the air cleaner adapter to fit the new carb, (it's a little bigger than original)
Just saying a few hours of work and less than $150 bucks and this is running the best it ever has. I will update once I really work the machine but it sure seams like this is fixed.
Nice .how you make the spacer? You have a mill?
Does your machine have some contraption that runs off of engine belt that has linkages to carburertor? Looks like a mini smog pump but its not. Weird thing i dont think its a governor
A car carb doesnt have accelerator pump does it? Does it have the governor like in photo? If it does is it still operational?
    367.1 KB
    419.4 KB
Nice fix! What year Lancer did you get a carb for? I need to add a shut off solenoid to mine also.
Just got to ebay and search for 4g32 carburetor but they dont have accelerator pumps .dont know if it matters much. He doesnt use a solenoid .he running an electric fuel pump wired up to ignition switch. I dont know why it needs a fuel shut off solenoid anyway if it has an ignition coil shut off with the key.​
Yes, I have the same govenor and the carb I bought does have an accelerator pump internal. Made the spacer on my mill but could be done on a drill press. 1/2 inch aluminum and I used holes saws for bores. Used the pastic spacer for a templet.
I never saw a carb with internal accelerator pump since they all need a lever attached to throttle somehow. Even on little dirt bikes theyre external. Maybe its the plunger thingy
    1.4 MB
Yep that is the same accelerator pump. Should have said integral not internal. I know how people like to slam.
All good! I'm done
The electric fuel shut off is helpful in preventing fuel from the higher level in the tank from flowing into the carb when the machine is off. The needle and seat in the carb does shut it off but as the fuel evaporates in the carb the tank keeps filling it. The electric cut off prevents this.
Ha just put an inline shutoff valve easy peezy. I guess . hey tlaskey can you text me i got some questions and pics to show you. Email or text me please. [email protected] or 740 738 3001
Got a pic of it on the engine? What about the factory spacer plate? What does that large vacuum nipple go to?
    307.4 KB
My 742B has no vacuum under any throttle positions at that large vacuum nipple. It appears to be blocked off. I would call it a dummy that is not used in this application.
The big vacuum port on mine is open. Do you have the part# on your carb mine is in photo.maybe mine off something else.?
28-32DID SA27
If there is not a hose in need of a vacuum source that is not hooked up, I would just cap the nipple off. Being that yours is now an automotive carb, that port could have been used for something like power brakes.....that I am guessing you don't have. Cap it off, you will be fine.
View attachment 2677View attachment 2678View attachment 2679
I did much the same--bought an ebay carb, made a 1/2 inch spacer, made a longer governor rod, made a new connector piece to go on the butterfly shaft with the right angle for the slot so it would best connect to the governor rod, and dinked with it a little so that the butterfly opened only to fully open, not beyond full open, and adjusted the throttle lever for fast and slow speeds. As to blocking the secondary, I just made a single hole in the 1/2 inch spacer, and disconnected the vacuum mechanism that opened the secondary butterfly. Seems to work fine and runs better than before--always seemed overly rich in the past--nasty exhaust. I do wonder if it is now running too lean, in that an auto carb would be looking for fuel economy, and a Bobcat for maximum torque (meaning running somewhat richer than optimum for economy). The only downside that I have definitely noted is that there are two nozzles for the accelerator pump, so the secondary nozzle squirts into a blocked off hole, and eventually leaks out around the butterfly shaft thence to outside the carb. Not much of a problem since you generally set the engine to one speed and leave it there. Had I anticipated this I might have soldered it shut, but am just leaving it for now.
forgot--has to make an adapter for the carb to intake casting too.
