Hello, I just bought a 731 that has a right drive issue. It groans fairly loud when you try to get it to drive. I tore the drive motor down, and it looks fine inside, with the exception of the spring loaded valve at the bottom had a broken spring. I replaced all the parts in there with new, and a new seal kit, but the problem didn't change. The motor had very few scratches on the rotating surfaces inside. The bone shaped gear looked like new. I replaced the main filter, and cleaned the one in the line block (saw it in another post on here) middle line (it was clean already) Any one have any suggestions? Are these drive motors common to fail? If yes, any ideas on where to find a used one, or good recomendation for a rebuilder? Thanks, Rod
