6620 wheels won't stop moving
moviegib
have a 95 6620 with 3500 hours, wheels are always moving when the machine is cold,which is tough on the starter when starting in cold weather, any ideas for a fix thanx moviegib
The centering adjustments for the steering levers need to be re adjusted so the pumps that power your wheels are in neutral when the levers are released. This is a common skidsteer adjustment. No idea how it is done on your model though.
Exactly what i was going to say, but i can't tell you the procedure either....
Don't worry, its not a fault as such, just an adjustment.
Just for now, if you know what way its trying to move you can hold the sticks back or forward a little so its not fighting against the engine while trying to start. The other way is to kick the brake off before you crank, then if it does want to move it will have the least amount of resistance.
