T770 emissions delete
jca57jd
Hey guys Im looking at buying a used T770 highflow to use Mulching. The unit im looking at is a 2014 or 2015 model with the t4i kubota motor in it (pre complete tier 4) with only 200 hours. I found a company that offers a ecm reflash for this model that increases the horsepower and overrides all the emissions sensors on the computer. My question is has anybody deleted the dpf, Regen system, and egr on one of these yet?
I haven't heard of anyone doing it before, but that may just be because they don't want to get in trouble :)
Did you do it? Pm me if you have info please.
Just a little hint, you have an SCR ands DOC on your machine.
Also, just from experience, if you delete the system no Bobcat Dealer will ever touch the machine again.
And usually the machine does not run 100% correct, because they have to use a Serial # from a other machine and then all controllers start spitting weird codes.
That is good to know but also sucks. That crap is not fun to maintain or pay for.
Basically make sure that all gaskets are always good, all holding brackets tight, always enough DEF fluid in the system and never run your machine in low idle for a long time. Always full idle, only slow down when you get out or when loading/unloading.
I got a question for the cowboy since you recently got out of the shop, what is concidered to be long time as idle time goes?? All the manf. mention this but none that I have seen actually put a number on this timeframe.
I wanna say everything over 5 min is considered long idle
