642b tilt cylinder dropping
mmd2803
I recently purchased a 642b. It had been sitting for 2.5 years. 5 minutes into using it the tilt cylinder started spraying fluid. So I rebuilt that and the right lift cylinder since it was leaking too. Then the back line on the lift cylinder blew so I replaced that. When that blew it obviously lost most of the fluid. I added 2.5 gallons and used it a bit. The tilt cylinder would not hold up the bucket. I assumed it needed more fluid. I filled the tank. The bucket still won't hold. And when there is any weight in it it drops faster. When I dump a load with the bucket high and tilt all the way down I have to use the ground to "re-engage" the tilt. It won't tilt the bucket without assistance. Sorry so long, wanted to get all the info.
Thanks for Any help.
