463 manuals, and noise after warm
backwoodsguy
Hi folks, Recently picked up a 463 to do some snow removal and yard work, just wondering if a manual is available online? I've searched, but no luck thus far. Also, it seems to be making an odd sound from beneath the seat, not a grind or whine as such, but not a normal sound that isn't heard when its first started and run a bit. I plan to flip the cab up this afternoon, but being such a newb, have no idea what things I should be checking for. Any help would be greatly appreciated. Thanks
Manuals are available from the dealer or ebay.
Does it make the noise shen the park brake is off? or when the brake is on? does it creep?
ty kindly re: the manuals.. I'll check prices locally before I order from ebay. Turned out she has a leak, and the hydrostatic/hyd fluid was getting low... explains the noise and goes away when I top it up... however now to find the leak...
Get a bunch of cans of degreaser, lift the cab and give it a good degrease and pressure wash. When its all dry and clean, its much easier to find any leaks. If its been leaking for a while, there will be a lot of crud caked up under the cab..... Been there, done taht many times before.
