272c oil and maintance advice?
1ajs
got a 2008 272c was not well cared for got it with 2010hrs never had any fluid changes as best anyone can tell if it did woulda been 8plus yrs ago. done maybe only 100hrs since 2011. stored outside since 2011. spent several yrs parked. put 15/40 in it needs a new shock for cab lift on one side. (snaped off) so spec on a replacement be nice if anyone knows oil for hydraulics and the chain drive? filters? tires are worn have tubes in them cat wasn't very helpfull on info they just wanted to sell me a shop manual for $1500 or pay them 2k to come look at it. i live where temps can get down to -40 in the winter. currently have the block heater plugged in before i fire it up and let sit for half and hr idling before i use it. open cab so plan to get some lexan to seal it up and install a vent with a fan for heat. also plan on putting a rear camera on it so i can see behind me.
Hyd is advance 10 wt ( 10 wt hyd oil) Chains take engine oil 15w40 Hyd filter is 1g8878
The machine has the following approx service schedule: Engine oil and filter 250 hrs Hyd oil and filter 1000 hrs Chain case oil 1000 hrs
